Api session event editor source add catalog
API Endpoint to Add Catalog
| 0 | REQUIRED | (Enumeration) | GeoCatalog | CSW or ESRI |
| 1 | REQUIRED | (String) | String | |
| 2 | REQUIRED | (String) | String |
| 200 | Integer (Integer) |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorsource/add_catalog/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "CSW", "Text", "Text" ]'JavaScript Example POST:
body: '[ "CSW", "Text", "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorsource/add_catalog/", options)
