Api session event editor setting wizard finished
API Endpoint to Wizard Finished
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorsetting/wizard_finished/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ ]'JavaScript Example POST:
body: '[ ]'
fetch("https://engine.tygron.com/api/session/event/editorsetting/wizard_finished/", options)
