Api session event editor setting set rasterization
API Endpoint to Set Rasterization
| 0 | REQUIRED | (Enumeration) | RasterizationMethod | CENTER, COMBINED or OUTLINE |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_rasterization/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"COMBINED"'JavaScript Example POST:
body: '"COMBINED"'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_rasterization/", options)
