Api session event editor setting set panel availability
Revision as of 09:11, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Set Panel Availability
0 REQUIRED (Enumeration) PanelEnum ACTION_LOG_PANEL, ATTRIBUTE_ACTION_PANEL, BUDGET_PERSONAL_PANEL, CATEGORY_PANEL, ERROR_PANEL, FEEDBACK_PANEL, FLYTHROUGH_PANEL, GLOBAL_EDIT_PANEL, GRID_OPTION_PANEL, HOVER_PANEL, INDICATOR_PANEL, INDICATOR_PARENT_PANEL, LAND_BUY_PANEL, LAND_SELL_PANEL, LEFT_MENU_PANEL, LOG_PANEL, LOGO_PANEL, MENU_PANEL, MONEY_TRANSFER_PANEL, NAVIGATION_PANEL, OVERLAY_LEGEND_PANEL, POPUP_ARROW_BOTTOM_LEFT_PANEL, POPUP_ARROW_BOTTOM_PANEL, POPUP_ARROW_BOTTOM_RIGHT_PANEL, POPUP_ARROW_LEFT_PANEL, POPUP_ARROW_RIGHT_PANEL, POPUP_ARROW_TOP_LEFT_PANEL, POPUP_ARROW_TOP_PANEL, POPUP_ARROW_TOP_RIGHT_PANEL, POPUP_INFO_PANEL, SELECTION_LEGEND_PANEL, SETTINGS_PANEL, SWITCH_PANEL, TOPBAR_PANEL, WEB_BROWSER_PANEL or ZONING_PERMIT_PANEL
1 REQUIRED (true, false) Boolean true or false
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_panel_availability/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "ATTRIBUTE_ACTION_PANEL", false ]'
JavaScript Example POST:
 body: '[ "ATTRIBUTE_ACTION_PANEL", false ]'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_panel_availability/", options)
