Api session event editor setting get epoch time
Revision as of 09:11, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Get UTC Epoch Time (Milliseconds since 00:00:00 UTC on 1 January 1970) for local Time in this Project
0 REQUIRED (Integer number) Year
1 REQUIRED (Integer number) Month
2 REQUIRED (Integer number) Day
3 REQUIRED (Integer number) Hour
4 REQUIRED (Integer number) Minute
5 REQUIRED (Integer number) Second
200 Long (UTC Epoch Time (Milliseconds since 00:00:00 UTC on 1 January 1970))
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorsetting/get_epoch_time/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 2005, 9, 1, 0, 0, 0 ]'
JavaScript Example POST:
 body: '[ 2005, 9, 1, 0, 0, 0 ]'
fetch("https://engine.tygron.com/api/session/event/editorsetting/get_epoch_time/", options)
