Api session event editor scenario set restart testrun
Revision as of 09:11, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to When true test run is restarted on Scenario activation. This option will be deprecated in the future and replaced by multiple maps.
0 REQUIRED (SCENARIO Integer ID or multiple values in array [1, 2, 3]) Scenario ID
1 REQUIRED (Boolean or multiple values in array [true, false, true]) Restart required
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorscenario/set_restart_testrun/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorscenario/set_restart_testrun/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ true, false, true ] ]'
JavaScript Example POST:
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorscenario/set_restart_testrun/", options)
