Api session event editor scenario set cinematic
API Endpoint to Set Cinematic
| 0 | REQUIRED | (SCENARIO Integer ID) | Scenario | |
| 1 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder | |
| 2 | REQUIRED | (CINEMATIC_DATA Integer ID) | Cinematic |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorscenario/set_cinematic/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1 ]'JavaScript Example POST:
body: '[ 1, 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorscenario/set_cinematic/", options)
