Api session event editor scenario remove cinematic
Revision as of 09:11, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Remove Cinematic
0 REQUIRED (SCENARIO Integer ID) Scenario
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorscenario/remove_cinematic/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript Example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorscenario/remove_cinematic/", options)
