Api session event editor parametric generate
Revision as of 09:10, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Generate
0 REQUIRED (PARAMETRIC_DESIGN Integer ID) Parametric Design
200 PDResult (PDResult)
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorparametric/generate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript Example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorparametric/generate/", options)
