Api session event editor parametric set attribute
API Endpoint to Set Parametric attribute value
| 0 | REQUIRED | (PARAMETRIC_DESIGN Integer ID or multiple values in array [1, 2, 3]) | Parametric Design | |
| 1 | REQUIRED | (String) | Attribute Name | |
| 2 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Attribute Values | |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorparametric/set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name", 1.0, "" ]'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorparametric/set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], "Attribute Name", [ 1.0, 2.0, 3.0 ], "" ]'JavaScript Example POST:
body: '[ 1, "Attribute Name", 1.0, "" ]'
fetch("https://engine.tygron.com/api/session/event/editorparametric/set_attribute/", options)
