Api session event editor panel remove answer event
API Endpoint to Remove Answer (Panel) Event
| 0 | REQUIRED | (PANEL Integer ID) | Panel | |
| 1 | REQUIRED | (Integer number) | Integer | |
| 2 | REQUIRED | (true, false) | Boolean | true or false |
| 3 | REQUIRED | (Integer number) | Integer |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorpanel/remove_answer_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true, 1 ]'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorpanel/remove_answer_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, false, 1 ]'JavaScript Example POST:
body: '[ 1, 1, true, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/remove_answer_event/", options)
