Api session event editor panel add overlay template
Revision as of 09:10, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Add Overlay Template
0 REQUIRED (Enumeration) PanelTemplate DANGEROUS_OBJECTS, NETWORK_INTERACTION, TRAFFIC_NOISE, WATER_AREAS or WEIRS
1 REQUIRED (OVERLAY Integer ID) Overlay
200 Integer (Integer)
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorpanel/add_overlay_template/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "TRAFFIC_NOISE", 1 ]'
JavaScript Example POST:
 body: '[ "TRAFFIC_NOISE", 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/add_overlay_template/", options)
