Api session event editor panel add global
Revision as of 09:09, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Add Global
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (GLOBAL Integer ID or multiple values in array [1, 2, 3]) Global
200 String (String)
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorpanel/add_global/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorpanel/add_global/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'
JavaScript Example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/add_global/", options)
