Api session event editor overlay remove water weather
API Endpoint to Remove Water Weather
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editoroverlay/remove_water_weather/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript Example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/remove_water_weather/", options)
