Api session event editor netsetting set cluster fraction connected
Revision as of 09:08, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Set Cluster Fraction Connected
0 REQUIRED (Floating point number) Double
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editornetsetting/set_cluster_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '3'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editornetsetting/set_cluster_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '75'
JavaScript Example POST:
 body: '3'
fetch("https://engine.tygron.com/api/session/event/editornetsetting/set_cluster_fraction_connected/", options)
