Api session event editor netload import net
API Endpoint to Import Net
| 0 | REQUIRED | (GeometryCollection with crs: EPSG:3857) | GeometryCollection | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] | |
| 2 | REQUIRED | (NetType or multiple values in array [a, b, c]) | NetType[] | |
| 3 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] | |
| 4 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) | double[][] | |
| 5 | REQUIRED | (GeometryCollection with crs: EPSG:3857) | GeometryCollection | |
| 6 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] | |
| 7 | REQUIRED | (NetType or multiple values in array [a, b, c]) | NetType[] | |
| 8 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] | |
| 9 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) | double[][] | |
| 10 | REQUIRED | (GeometryCollection with crs: EPSG:3857) | GeometryCollection | |
| 11 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] | |
| 12 | REQUIRED | (NetType or multiple values in array [a, b, c]) | NetType[] | |
| 13 | REQUIRED | (TimeState or multiple values in array [a, b, c]) | TimeState[] | |
| 14 | REQUIRED | (Boolean or multiple values in array [true, false, true]) | Boolean[] | |
| 15 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] | |
| 16 | REQUIRED | (Integer number or multiple values in array [1, 2, 3]) | Integer[] | |
| 17 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] | |
| 18 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) | double[][] | |
| 19 | REQUIRED | (Floating point number) | Double | |
| 20 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editornetload/import_net/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
"type" : "GeometryCollection",
"geometries" : [ {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, "Text 1", "ELECTRICITY", "Text 1", [ 1.0, 2.0 ], {
"geometries" : [ {
"geometries" : [ {
}, "Text 1", "ELECTRICITY", "NOTHING", true, "Text 1", 1, "Text 1", [ 1.0, 2.0 ], 50, 25 ]
'Curl Example multi item POST:
"geometries" : [ {
"coordinates" : [ [ [ [ 658646.762, 6799451.896 ], [ 658646.762, 6799461.896 ], [ 658656.762, 6799461.896 ], [ 658656.762, 6799451.896 ], [ 658646.762, 6799451.896 ] ] ] ]
"coordinates" : [ [ [ [ 658656.762, 6799451.896 ], [ 658656.762, 6799461.896 ], [ 658666.762, 6799461.896 ], [ 658666.762, 6799451.896 ], [ 658656.762, 6799451.896 ] ] ] ]
}, [ "Text 1", "Text 2", "Text 3" ], [ "ELECTRICITY", "GAS", "HEAT" ], [ "Text 1", "Text 2", "Text 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], {
"geometries" : [ {
"geometries" : [ {
}, [ "Text 1", "Text 2", "Text 3" ], [ "ELECTRICITY", "GAS", "HEAT" ], [ "NOTHING", "WAITING_FOR_DATE", "REQUEST_PLOT_OWNER_APPROVAL" ], [ true, false, true ], [ "Text 1", "Text 2", "Text 3" ], [ 1, 2, 3 ], [ "Text 1", "Text 2", "Text 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], 80, 24 ]
'JavaScript Example POST:
body: '[ { "type" : "GeometryCollection", "geometries" : [ { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ] } ]}, "Text 1", "ELECTRICITY", "Text 1", [ 1.0, 2.0 ], { "type" : "GeometryCollection", "geometries" : [ { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ] } ]}, "Text 1", "ELECTRICITY", "Text 1", [ 1.0, 2.0 ], { "type" : "GeometryCollection", "geometries" : [ { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ] } ]}, "Text 1", "ELECTRICITY", "NOTHING", true, "Text 1", 1, "Text 1", [ 1.0, 2.0 ], 50, 25 ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/import_net/?crs=3857", options)
