Api session event editor netload add and set node
Revision as of 09:08, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Add And Set Node
0 REQUIRED (NET_LOAD Integer ID) Net Load
1 REQUIRED (Point with crs: EPSG:3857) Point
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editornetload/add_and_set_node/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658756.7546502809, 6799343.837240523 ]
Curl Example multi item POST:
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658747.4174918773, 6799401.888098395 ]
JavaScript Example POST:
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658756.7546502809, 6799343.837240523 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/add_and_set_node/?crs=3857", options)
