Api session event editor netline remove attribute
API Endpoint to Remove the specified attributes for each specified Net Line
| 0 | REQUIRED | (NET_LINE Integer ID or multiple values in array [1, 2, 3]) | Net Line IDs | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Attributes |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editornetline/remove_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute 1" ]'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editornetline/remove_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Attribute 1", "Attribute 2", "Attribute 3" ] ]'JavaScript Example POST:
body: '[ 1, "Attribute 1" ]'
fetch("https://engine.tygron.com/api/session/event/editornetline/remove_attribute/", options)
