Api session event editor measure set levee height relative
Revision as of 09:07, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Set whether the inner height of Levee Spatial of a Measure is considered relative.
0 REQUIRED (MEASURE Integer ID) Measure IDs
1 REQUIRED (Integer number) Levee Spatial ID
2 OPTIONAL (true, false) Boolean
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editormeasure/set_levee_height_relative/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "" ]'
JavaScript Example POST:
 body: '[ 1, 1, "" ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/set_levee_height_relative/", options)
