Api session event editor global add
Revision as of 09:05, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Add new Global
200 Integer (Integer)
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorglobal/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ ]'
JavaScript Example POST:
 body: '[ ]'
fetch("https://engine.tygron.com/api/session/event/editorglobal/add/", options)
