Api session event editor geotiff add ascii
API Endpoint to Add new GeoTIFF Item with provided ASCII file. For files larger than 2GB, use the Stream API or Web URL.
| 0 | REQUIRED | (String) | GeoTIFF Name | |
| 1 | REQUIRED | (byte or multiple values in array [a, b, c]) | ASCII File bytes (< 2GB) | |
| 2 | REQUIRED | (String) | Uploader | |
| 3 | REQUIRED | (String) | CRS |
| 200 | Integer (GeoTIFF ID) |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/add_ascii/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GeoTIFF Name", 1, "Uploader", "CRS" ]'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/add_ascii/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GeoTIFF Name", [ 1, 2, 3 ], "Uploader", "CRS" ]'JavaScript Example POST:
body: '[ "GeoTIFF Name", 1, "Uploader", "CRS" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeotiff/add_ascii/", options)
