Api session event editor cinematic set keypoint description
Revision as of 09:03, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Set Keypoint Description
0 REQUIRED (CINEMATIC_DATA Integer ID) Cinematic
1 REQUIRED (Integer number) Integer
2 REQUIRED (String) String
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorcinematic/set_keypoint_description/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Text" ]'
JavaScript Example POST:
 body: '[ 1, 1, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/set_keypoint_description/", options)
