Api session event editor area generate sewer areas
API Endpoint to Generate Sewer Area
| 0 | REQUIRED | (Integer number) | Integer | |
| 1 | REQUIRED | (Floating point number) | Double | |
| 2 | REQUIRED | (Floating point number) | Double | |
| 3 | REQUIRED | (Floating point number) | Double | |
| 4 | REQUIRED | (String) | String |
| 200 | Integer (Integer) |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_sewer_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 18, 44, 48, "Text" ]'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_sewer_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 46, 1, 28, "Text" ]'JavaScript Example POST:
body: '[ 1, 18, 44, 48, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/generate_sewer_areas/", options)
