Api session event editor area add with attribute
Revision as of 09:02, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Add With Attribute
0 REQUIRED (String) String
1 REQUIRED (Floating point number) Double
200 Integer (Integer)
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/add_with_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", 40 ]'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/add_with_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", 32 ]'
JavaScript Example POST:
 body: '[ "Text", 40 ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/add_with_attribute/", options)
