Api session event editor address remove
Revision as of 09:02, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Remove existing Address
0 REQUIRED (ADDRESSE Integer ID or multiple values in array [1, 2, 3]) Address
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editoraddress/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoraddress/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript Example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editoraddress/remove/", options)
