Api session event editor area generate sewer areas
API endpoint to Generate Sewer Area
| 0 | REQUIRED | (Integer number) | Integer | |
| 1 | REQUIRED | (Floating point number) | Double | |
| 2 | REQUIRED | (Floating point number) | Double | |
| 3 | REQUIRED | (Floating point number) | Double | |
| 4 | REQUIRED | (String) | String |
| 200 | Integer (Integer) |
Curl Example POST:
curl=API_TOKENCurl Example multi item POST:
curl=API_TOKEN
