Api session event editor area remove attribute
Revision as of 08:52, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API endpoint to Remove attribute from Area
0 REQUIRED (AREA Integer ID or multiple values in array [1, 2, 3]) Area
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) String[]
204 No Content
Curl Example POST:
curl=API_TOKEN
Curl Example multi item POST:
curl=API_TOKEN
