Api session event editor clear map
API endpoint to Remove all geospatial data of the Project, such as Building, Area, etc.
| 0 | REQUIRED | (true, false) | Delete the map size and georeference too (false means deleting only the geodata) | true or false |
| 204 | No Content |
Curl Example POST:
curl=API_TOKENCurl Example multi item POST:
curl=API_TOKEN
