Api session event editor activate testrun
API Event to Start or stop a Scenario Testrun.
0 REQUIRED (true, false) Start the Scenario Testrun (false means stop) true or false
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editor/activate_testrun/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'false'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editor/activate_testrun/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'true'
JavaScript Example POST:
 body: 'false'
fetch("https://development.tygron.com/api/session/event/editor/activate_testrun/", options)
