Api session event editor trigger add
Revision as of 06:57, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add new Trigger
0 OPTIONAL (Timing or multiple values in array [a, b, c]) Timing[]
200 Integer[] (Integer array)
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editortrigger/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '""'
JavaScript Example POST:
 body: '""'
fetch("https://development.tygron.com/api/session/event/editortrigger/add/", options)
