Api session event editor stakeholder select stakeholder
API Event to Select Stakeholder with preferred ID, when not available fallback to next best.
| 0 | REQUIRED | (Integer number) | Preferred Stakeholder ID or empty | |
| 1 | REQUIRED | (String) | Client Token (from Join Session event) |
| 200 | Integer (Selected Stakeholder ID) |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorstakeholder/select_stakeholder/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Client Token" ]'JavaScript Example POST:
body: '[ 1, "Client Token" ]'
fetch("https://development.tygron.com/api/session/event/editorstakeholder/select_stakeholder/", options)
