Api session event editor sound set volume
API Event to Set Volume
| 0 | REQUIRED | (SOUND Integer ID) | Sound | |
| 1 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorsound/set_volume/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 95 ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorsound/set_volume/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 54 ]'JavaScript Example POST:
body: '[ 1, 95 ]'
fetch("https://development.tygron.com/api/session/event/editorsound/set_volume/", options)
