Api session event editor setting set permission popup active
Revision as of 06:56, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Permission Popup Active
0 REQUIRED (true, false) Boolean true or false
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorsetting/set_permission_popup_active/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d 'false'
JavaScript Example POST:
 body: 'false'
fetch("https://development.tygron.com/api/session/event/editorsetting/set_permission_popup_active/", options)
