Api session event editor scenario set restart testrun
API Event to When true test run is restarted on Scenario activation. This option will be deprecated in the future and replaced by multiple maps.
| 0 | REQUIRED | (SCENARIO Integer ID or multiple values in array [1, 2, 3]) | Scenario ID | |
| 1 | REQUIRED | (Boolean or multiple values in array [true, false, true]) | Restart required |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorscenario/set_restart_testrun/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorscenario/set_restart_testrun/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ true, false, true ] ]'JavaScript Example POST:
body: '[ 1, true ]'
fetch("https://development.tygron.com/api/session/event/editorscenario/set_restart_testrun/", options)
