Api session event editor parametric set function
Revision as of 06:56, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Function
0 REQUIRED (PARAMETRIC_DESIGN Integer ID or multiple values in array [1, 2, 3]) Parametric Design
1 REQUIRED (FunctionType or multiple values in array [a, b, c]) FunctionType[]
2 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Integer[]
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorparametric/set_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "ROAD", 1 ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorparametric/set_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "ROAD", "WATER", "PARKING" ], [ 1, 2, 3 ] ]'
JavaScript Example POST:
 body: '[ 1, "ROAD", 1 ]'
fetch("https://development.tygron.com/api/session/event/editorparametric/set_function/", options)
