Api session event editor panel set point
Revision as of 06:55, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Point
0 REQUIRED (PANEL Integer ID) Panel
1 OPTIONAL (Point with crs: EPSG:3857) Point
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorpanel/set_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "" ]'
JavaScript Example POST:
 body: '[ 1, "" ]'
fetch("https://development.tygron.com/api/session/event/editorpanel/set_point/?crs=3857", options)
