Api session event editor overlay set parent
Revision as of 06:54, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set a parent Overlay for a specified Overlay. This will cause the specified Overlay to be a subselectable Overlay of the parent. It is not possible to set an Overlay which has a parent itself as a parent of another Overlay.
0 REQUIRED (OVERLAY Integer ID) Overlay ID
1 REQUIRED (Integer number) Overlay ID of parent (Overlay without a parent should have their parent Overlay ID set to -1)
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editoroverlay/set_parent/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript Example POST:
 body: '[ 1, 1 ]'
fetch("https://development.tygron.com/api/session/event/editoroverlay/set_parent/", options)
