Api session event editor overlay set key value
API Event to Change a key for a specified Overlay. The Overlay must be an Overlay which makes use of keys to read attributes of geographical items, as input for its calculation.
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay ID (must relate to a grid Overlay) | |
| 1 | REQUIRED | (String) | Key name | |
| 2 | REQUIRED | (String) | Attribute to look for |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editoroverlay/set_key_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Key name", "Attribute to look for" ]'JavaScript Example POST:
body: '[ 1, "Key name", "Attribute to look for" ]'
fetch("https://development.tygron.com/api/session/event/editoroverlay/set_key_value/", options)
