Api session event editor overlay set heat model
Revision as of 06:54, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Heat Model
0 REQUIRED (OVERLAY Integer ID) Overlay
1 REQUIRED (Enumeration) HeatModel DPRA or UNESCO
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editoroverlay/set_heat_model/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "UNESCO" ]'
JavaScript Example POST:
 body: '[ 1, "UNESCO" ]'
fetch("https://development.tygron.com/api/session/event/editoroverlay/set_heat_model/", options)
