Api session event editor overlay add result child
Revision as of 06:54, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add a specified result type as a child Overlay to a specified grid Overlay. The child Overlay's result will be based on the parent's calculation, allowing you to get multiple types of results from the same calculation.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to a grid Overlay with result types)
1 REQUIRED (String) Result type for new child Overlay (must be a valid result for the parent Overlay type)
200 Integer (Overlay ID)
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editoroverlay/add_result_child/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Result type for new child Overlay" ]'
JavaScript Example POST:
 body: '[ 1, "Result type for new child Overlay" ]'
fetch("https://development.tygron.com/api/session/event/editoroverlay/add_result_child/", options)
