Api session event editor overlay remove attribute
Revision as of 06:54, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove the specified attributes of the specified Overlay. The attributes, including attributes which are added to an Overlay by default, are removed entirely.
0 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay ID
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attributes to remove
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editoroverlay/remove_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attributes to remove 1" ]'
Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editoroverlay/remove_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Attributes to remove 1", "Attributes to remove 2", "Attributes to remove 3" ] ]'
JavaScript Example POST:
 body: '[ 1, "Attributes to remove 1" ]'
fetch("https://development.tygron.com/api/session/event/editoroverlay/remove_attribute/", options)
