Api session event editor netload remove building
API Event to Remove Building
| 0 | REQUIRED | (NET_LOAD Integer ID) | Net Load |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editornetload/remove_building/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript Example POST:
body: '1'
fetch("https://development.tygron.com/api/session/event/editornetload/remove_building/", options)
