Api session event editor netload remove attribute
API Event to Remove attribute from Net Load
| 0 | REQUIRED | (NET_LOAD Integer ID or multiple values in array [1, 2, 3]) | Net Load | |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editornetload/remove_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text 1" ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editornetload/remove_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Text 1", "Text 2", "Text 3" ] ]'JavaScript Example POST:
body: '[ 1, "Text 1" ]'
fetch("https://development.tygron.com/api/session/event/editornetload/remove_attribute/", options)
