Api session event editor netfunction import
API Event to Import multiple Net Functions
| 0 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] | |
| 1 | REQUIRED | (NetType or multiple values in array [a, b, c]) | NetType[] | |
| 2 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] | |
| 3 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) | double[][] | |
| 4 | REQUIRED | (SOURCE Integer ID) | Source |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editornetfunction/import/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text 1", "ELECTRICITY", "Text 1", [ 1.0, 2.0 ], 1 ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editornetfunction/import/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ "Text 1", "Text 2", "Text 3" ], [ "ELECTRICITY", "GAS", "HEAT" ], [ "Text 1", "Text 2", "Text 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], 1 ]'JavaScript Example POST:
body: '[ "Text 1", "ELECTRICITY", "Text 1", [ 1.0, 2.0 ], 1 ]'
fetch("https://development.tygron.com/api/session/event/editornetfunction/import/", options)
