Api session event editor measure set terrain height relative
Revision as of 06:52, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set whether the inner height of Terrain Spatial of a Measure is considered relative.
0 REQUIRED (MEASURE Integer ID) Measure IDs
1 REQUIRED (Integer number) Terrain Spatial ID
2 REQUIRED (true, false) Boolean true or false
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editormeasure/set_terrain_height_relative/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'
JavaScript Example POST:
 body: '[ 1, 1, true ]'
fetch("https://development.tygron.com/api/session/event/editormeasure/set_terrain_height_relative/", options)
