Api session event editor measure set terrain height
API Event to Set the inner height of Terrain Spatial of a Measure.
| 0 | REQUIRED | (MEASURE Integer ID) | Measure IDs | |
| 1 | REQUIRED | (Integer number) | Terrain Spatial ID | |
| 2 | REQUIRED | (Floating point number) | Height value |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editormeasure/set_terrain_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 21 ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editormeasure/set_terrain_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 28 ]'JavaScript Example POST:
body: '[ 1, 1, 21 ]'
fetch("https://development.tygron.com/api/session/event/editormeasure/set_terrain_height/", options)
