Api session event editor levee set angle degrees
API Event to Set Angle Degrees
| 0 | REQUIRED | (LEVEE Integer ID) | Levee | |
| 1 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorlevee/set_angle_degrees/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 72 ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorlevee/set_angle_degrees/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 9 ]'JavaScript Example POST:
body: '[ 1, 72 ]'
fetch("https://development.tygron.com/api/session/event/editorlevee/set_angle_degrees/", options)
