Api session event editor indicator set update timing
API Event to Set Update Timing
| 0 | REQUIRED | (INDICATOR Integer ID or multiple values in array [1, 2, 3]) | Indicator | |
| 1 | REQUIRED | (Timing or multiple values in array [a, b, c]) | Timing[] |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorindicator/set_update_timing/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "BEFORE" ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorindicator/set_update_timing/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "BEFORE", "AFTER", "AFTER" ] ]'JavaScript Example POST:
body: '[ 1, "BEFORE" ]'
fetch("https://development.tygron.com/api/session/event/editorindicator/set_update_timing/", options)
