Api session event editor global set point
Revision as of 06:51, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Point
0 REQUIRED (GLOBAL Integer ID) Global
1 REQUIRED (Point with crs: EPSG:3857) Point
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorglobal/set_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658726.73087045, 6799442.255802397 ]
Curl Example multi item POST:
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658795.0192966519, 6799323.574839511 ]
JavaScript Example POST:
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658726.73087045, 6799442.255802397 ]} ]'
fetch("https://development.tygron.com/api/session/event/editorglobal/set_point/?crs=3857", options)
