Api session event editor geotiff set geotiff url
API Event to Update existing GeoTIFF Item from Web URL.
| 0 | REQUIRED | (GEO_TIFF Integer ID or multiple values in array [1, 2, 3]) | GeoTIFF ID | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Web URL | |
| 2 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Uploader | |
| 3 | OPTIONAL | (String or multiple values in array ["a", "b", "c"]) | CRS Override (optional) |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorgeotiff/set_geotiff_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Web URL 1", "Uploader 1", "" ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorgeotiff/set_geotiff_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Web URL 1", "Web URL 2", "Web URL 3" ], [ "Uploader 1", "Uploader 2", "Uploader 3" ], "" ]'JavaScript Example POST:
body: '[ 1, "Web URL 1", "Uploader 1", "" ]'
fetch("https://development.tygron.com/api/session/event/editorgeotiff/set_geotiff_url/", options)
